It is currently Sun Jul 05, 2026 2:06 pm
 Post subject: touchy / soft brakes .
PostPosted: Sun Jul 17, 2016 8:59 pm
Man my 78' has super touchy brakes . I mean really touchy and I can push the peddle t the stop . never really firms up . Brakes work great and will hold , but soft . New master , hoses bleed well , fluid flushed , all new wheel cylinders etc.
PostPosted: Mon Jul 18, 2016 9:37 pm
Rear drum? Are the primary and secondary shoes reversed?
PostPosted: Tue Jul 19, 2016 9:19 am
Hmmm .... Ill check
PostPosted: Thu Jul 28, 2016 2:49 pm
Brake booster failure . Put the old one from the yellow truck on it .... good to go. Booster was also full of brake fluid from a previous master rear seal failure .
PostPosted: Thu Jul 28, 2016 3:54 pm
There's also an adjustable rod between the booster & MC, it's length determines the travel of the MC piston- too short & less than full braking power, too long and the MC may not release fully.
PostPosted: Thu Jul 28, 2016 8:05 pm
I saw that . My master went straight up to the booster and didn't push the piston . Think im good.
