It is currently Fri Jul 03, 2026 8:36 am
 Post subject: Leaf springs?????
PostPosted: Wed Aug 26, 2015 8:38 pm
I have a 2wd 77 luv what size leaf spring are they I'm trying to replace them
 Post subject: Re: Leaf springs?????
PostPosted: Thu Aug 27, 2015 6:17 pm
Not sure on the size, I doubt you will find new ones on the shelf. Most have got a used set or send yours off to get re arched.
PostPosted: Sat Aug 29, 2015 9:05 am
Calvert racing has a split mono . The problem is they are 200# spring rate only . They don't make any other rates . Other than that stock is the only other option .
PostPosted: Sat Aug 29, 2015 1:37 pm
Re arch.. A good shop will make them like new again.... They are taken apart heated then re assembled. New center bolt, new bushings. At least the many I have had done.
PostPosted: Sat Aug 29, 2015 3:35 pm
I am actually have a set of springs re done now for a 1947 Caddy. Total cost with new bushings is $275. That should give you some kind of idea on cost.
PostPosted: Mon Aug 31, 2015 4:47 pm
http://www.sdtrucksprings.com/index.php ... &x=74&y=14
