It is currently Fri Jul 03, 2026 6:29 am
PostPosted: Thu Jul 30, 2015 1:39 pm
Is the 1984 s10 5 speed same as isuzu? Will it swap in a 1980 Luv?
PostPosted: Thu Jul 30, 2015 4:34 pm
If the S10 had the 1.9 engine it should work.
PostPosted: Thu Jul 30, 2015 7:14 pm
Make sure the tranny has an Isuzu emblem cast into the side of the case & not Borg-Warner & that the engine isn't a diesel, then make sure to get the splined shaft to mate to your driveshaft. If it is a gas Isuzu tranny it may not have the stronger internals of the '86-'95 models.
PostPosted: Sat Aug 01, 2015 6:52 am
It was the Borg Warner, damn only $30 bucks too..
