It is currently Sun Jul 05, 2026 3:56 am
 Post subject: narrowed rearend
PostPosted: Mon Mar 28, 2016 10:44 am
Will a 54" rearend tuck a 26x9 on the luvs ?thank you
 Post subject: Re: narrowed rearend
PostPosted: Mon Mar 28, 2016 2:14 pm
On mine the ford 9 inch was narrowed (Thank you Ben) to 51" and with stock frame rails it is close to the tire. I have 1/4 spacers behind each wheel for space. Now I am running 245/60/15 BFG TA's but it had wider tires on the rear when I got it, I don't know how close either are to a 26x9.
This was when I was installing the rear. The old tire was a 255/50/15
Here is a recent shot with the BFG's, not tucked but not rubbing either.
PostPosted: Tue Mar 29, 2016 1:55 pm
Thank you and nice truck !
PostPosted: Fri Apr 01, 2016 5:57 pm
54" s-10 rearend 26x9x15 tires fit pretty good. plenty of room between tire and frame also.
