It is currently Thu Jul 02, 2026 2:54 am
PostPosted: Sat Nov 08, 2014 8:49 am
Still have stock front end on the front of my76 Luv. Looking to get the right ride hight to order Shocks. I'm not home for a while need to order shocks. Ride high.
Killing all Big Blocks .
PostPosted: Sat Nov 08, 2014 11:54 am
Use stock shocks with a stock front suspension. If you changed the ride height by adjusting the torsion bars you haven't altered the suspension geometry, it still extends & compresses just like always, travel is limited by the bump stops and is still the same, so you don't need different length shocks.
PostPosted: Wed Nov 12, 2014 8:32 am
It's a high power small block buying double adjustable shocks. Stock shocks will not work.
PostPosted: Tue Nov 25, 2014 9:16 am
Some people have done coil spring conversions. Use the search function.
Users browsing this forum: Baidu [Spider] and 10 guests
