It is currently Wed Jul 01, 2026 5:58 am
 Post subject: radiator hoses
PostPosted: Wed May 07, 2014 3:27 pm
What are you guys with sbc swaps using for radiator hoses? I've tried 3 different sets now and am just about to buy some flexy stainless ones, but would rather not if there is a set of rubber ones that will work
I'm workin' on it
78 chassis with 75 cab
SBC
 Post subject: Re: radiator hoses
PostPosted: Wed May 07, 2014 10:06 pm
15 views and nothin?
I'm workin' on it
SBC
PostPosted: Wed May 07, 2014 10:24 pm
Too many variables to give an answer to for me. Location of the bungs on the tank, left right, straight up thermostat housing, etc. I generally just look at what I need by bending a clothes hanger to the approximate shape and go to the parts house and match up one, using the hanger as a pattern. Usually have to trim it to length...
PostPosted: Wed May 07, 2014 10:33 pm
im not a ton of help. i have s10 hoses i had to cut and mess with
the upper hose i had to cut off the part that goes over the tstat housing. i also have a swiveling tstat houaing so i could set it up to suit my layout
and the lower hose i had to cut a decent amount off of and soak the end in gas so it was pliable enough to push over the water pump barb.
but im running a 4.3 so my length is different. my in and outlet locations are the same layout as the stock gm type found in a sbc i would think. not sure how close you will find to a direct fitment
PostPosted: Wed May 07, 2014 11:04 pm
Never thought about using some wire, thanks for the tip! Hopefully tomorrow I can get some that'll fit
I'm workin' on it
SBC
PostPosted: Thu May 08, 2014 9:08 pm
I uses an 88-95 ish C 1500 lower that i cut a section out of . The top is a universal style . Measure the sizes on each end . Like 1.5" to 1 3/4" 14 " long as an example
