It is currently Wed Jul 01, 2026 8:43 am
 Post subject: Will this work?
PostPosted: Sat Mar 29, 2014 12:21 am
Hi, new to the site and I need to know if a g180 out of a 1974 luv will work in a 1978 luv. Thanks for any info.
 Post subject: Re: Will this work?
PostPosted: Sat Mar 29, 2014 7:45 pm
If the 74 is original style then no. Are the intake/exhaust manifolds on the same side?
PostPosted: Sun Mar 30, 2014 3:24 am
Yes they are. The 1974 is completely stock with about 50,000 original miles on it. Thanks for any info. Curious why this won't work. Can you explain?
PostPosted: Sun Mar 30, 2014 8:52 am
Starter is in the wrong side, engine mounts are differant and that is just the beginning.
PostPosted: Sun Mar 30, 2014 10:19 am
When I say it won't work. I mean it is not just a direct bolt in and go. If you have minimal fab skills, you can make it work. But as posted above, you got some work to do...
PostPosted: Sun Mar 30, 2014 1:29 pm
Thanks for the info. I should be able to fab something up and give it a try. Thanks for the help.
PostPosted: Sun Mar 30, 2014 3:56 pm
Just a thought, if you're going to go through all the trouble of fabbing and cutting and welding to make this motor work, why not try it with a better setup? A toyota 22r or a 4.3 v6 or something more reliable and with more parts available? Wouldn't be much difference in the amount of work required to make it work.
The 74 motor is a completely different motor than the 76-up motors.
PostPosted: Sun Mar 30, 2014 9:39 pm
I may just do that now that I am aware of what it takes to install the older engine. Could be a very good idea. Thanks
