It is currently Thu Jul 02, 2026 9:21 am
 Post subject: break in oil
PostPosted: Sat Mar 08, 2014 10:51 pm
Its getting to be about the time to pick up some break in oil. From what i have read it seems likr its slightly less critical with a roller valvetrain but what do you guys use and recommend? Was yhinking just get some of the compcams additive and run it with castrol like i usually use
 Post subject: Re: break in oil
PostPosted: Sun Mar 09, 2014 9:29 am
I never used it. Regular oil, run till the cam breaks in, change it and run.
PostPosted: Sun Dec 21, 2014 8:42 pm
Joe Gibbs racing oil has a break in oil. The newer oils don't have enough zinc (If I remember correctly). Also check Jegs or Summit and see what they are selling,
PostPosted: Sun Dec 21, 2014 9:40 pm
If your V6 is Hydraulic roller then you wont need it .
PostPosted: Mon Dec 22, 2014 6:46 am
I just use a crapload of assembly lube with regular ol 30 weight. Run the engine for 20 minutes or so and change the oil.
