It is currently Mon May 25, 2026 12:35 am
 Post subject: Need to know...
PostPosted: Tue Nov 04, 2003 12:28 am
Hey guys,
I need to know what kind of vehicle has a driveshaft that is 72 inches long (center of u-joint to center of u-joint) and is in ONE PEICE, no double U-jointed things. Oh ya and have a a spline to fit into a Chevy turbo 350 tranny! Thanks!
PostPosted: Tue Nov 04, 2003 1:54 am
well you might have better luck getting a drive shaft custom made for you. That aside i think that a Monza might have a drive shaft that length, im not shure though.
PostPosted: Tue Nov 04, 2003 9:37 am
Japanese Redneck
you can always look for a driveline that is longer than that and pay to have it shortened. they just cut the yolk off, reweld it and balance it. its not very expensive for that.
If you start out with a driveshaft that is too short and need it lengthened then they have to retube it so that costs about twice as much.
PostPosted: Wed Nov 12, 2003 10:00 pm
HUMMMM " RETUBE" I wonder if that will help ???? OH that was supposed to be just a thought
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Thu Nov 13, 2003 12:27 am
Ok,when building a custom driveline... how do you make the measurements for the driveshaft length? For instance, heres my prob. A driveshaft of a given length "x" will need to be longer at the point of longest axle travel. Correct? How doyou measure!?
