It is currently Thu Jul 02, 2026 8:49 pm
PostPosted: Sat Nov 02, 2013 2:56 pm
Has anyone had fit issues when installing a Pacesetter header on a 1.9 L? I have a 85 pup and with a metal/fiber manifold gasket combo, the header just squeezed by the clutch arm but I had to remove the E-brake bracket to complete the install.
I had to remove ALL the cables and hardware to remove rust from parts and threads so removing the bracket was needed anyway. I was hoping that someone else had experienced this problem and had come up with a fix. (Bend, relocate bracket)
I had to cut away a portion of the floor board behind the gas pedal. When installed the header pipe was 1/8" away from floor. I fabricated a new floor piece to move the floor two inches away from the header and applied heat shield.
Of course the collector ended up 8" from cross member. A quick trip to the pipe bender fixed that
Thanks
Bill
PostPosted: Wed Feb 11, 2015 10:48 am
Thanks
the pacesetter 70-1105 fit right into my 1.8 1980 Luv, but idk if there actually meant for the 1.9 even though sellers might claim they are.
Bill
Users browsing this forum: Google [Bot] and 34 guests
