It is currently Mon May 25, 2026 3:42 am
 Post subject: Distributor swap
PostPosted: Fri Feb 15, 2013 10:43 pm
I have a 1980 Chevy Luv, 2 wheel drive, with the 1.8 engine. There is a post about swapping the points distributor for electronic. It says I can use the 1987 Isuzu PUP 1.9 engine electronic distributor. I bought one at a junk yard but I can't get it to work. ?Does anybody know if this swap is even possible? And if it is. ?How and where are the electronic distributor wires connected?
 Post subject: Re: Distributor swap
PostPosted: Wed Feb 20, 2013 11:38 pm
I really can't help you much since I went with the Pertronix kit, but here is one thread that may help.
viewtopic.php?f=6&t=24620
I usually just hit the search bar and browse through the results, lots of good info comes up.
PostPosted: Thu Feb 21, 2013 9:42 am
Sorry put the wrong thread link :oops: , here are a couple more that may help.
viewtopic.php?f=5&t=23685&p=173397&hilit=isuzu+electronic+ignition#p173397
viewtopic.php?f=5&t=25026&p=183440&hilit=isuzu+electronic+ignition#p183440
