It is currently Thu Mar 19, 2026 4:07 am
PostPosted: Sun Sep 23, 2012 8:37 pm
got rearended and the bed is destroyed, bed is pushed into the cab and im sure insurance will total it
but the front end drivetrain should be fine
http://imgur.com/7dQCb
since diesel 4x4 are hard to find, how hard is it to swap the tranny and axle into a 2wd? may or may not want to do a 5sp upgrade at that time. right now i just need a truck and winter is fast approaching, will need 4wd in a few mos.
PostPosted: Sun Sep 23, 2012 8:52 pm
Sounds like you're suggesting making the 4x2 into a 4x4 (?). The front end is really different for the 4x4. Is the wrecked truck's frame bad? If the frame can be repaired, it would be easier to do a body/bed swap onto the 4x4 frame.
PostPosted: Sun Sep 23, 2012 11:13 pm
i dunno how bad it is. i can see that its physically buckled above the right rear wheel. i have no idea how repairable or what the cost would be to try and straighten it. seems like a relatively light gauge frame
PostPosted: Sat Oct 06, 2012 1:49 am
saying from expierence... the bed is toast... the frame and cab may be salvageable... if you can get the insurence to look past the bed hell if the frams bent less then an ince pull it back out and do a flat bed conversion....
Friends don't let friends drive stock...
76 mikado, emissions delete, dual alternator, rejetted 1.9 carb swap, non factory body lines
soon non points distributor, single (semi sealed beam) head light conversion
