love4theluv wrote:
by irect ignnition are you talking about the coil on plug setups with crank position sensors and such?
i would think it COULD be done using something like a ford edis setup to run it and a megajolt ignition only computer like ctmandu put on his stepside with the yamaha r1 carbs. megasquirt and megajolt are some advanced systems for how cheap they are.
http://www.diyautotune.com has most of their stuff
yep like ctmandus truck. but for a v8 setup. if i put a 350 in my luv id like to get the heads about 1" away from the fire wall. so no distributor setup. i liked how my V8 luv was. the front two pistons where all most over the spindles. but with my old luv i dont what to cut up the fire wall.
V8
old LUV
