It is currently Fri Apr 19, 2024 6:21 am
PostPosted: Thu Aug 09, 2012 10:24 pm
so I was getting ready to bolt on the automatic transmission when I noticed the pilot bearing... took it out and now the hole in the crank is 1.572" but the torque converter pilot is 1.088". I guess I need to have a bushing made, right?
PostPosted: Sat Jan 26, 2013 10:42 pm
okay, so I am a knuclehead at times! I got it in and running and drove her for the first time( I have had the truck for ten years) then found out I need a smog check! I am thinking of putting whatever went with the 84 impulse on if I could figure that out and see a referee. Then there is the low gearing issue (this auto transmission is only a 3 speed!? is that right? I thought it wasn't shifting into 4th gear but the transmission guy said it is only a 3 speed) looks like I need the entire drivetrain from an 86 isuzu pup
PostPosted: Sat Jan 26, 2013 10:46 pm
im pretty sure the 3rg gear in the auto is a 1:1 same as the 4th gear in the manual so that part should be okay.
as far as emissions go it varies by state. im not sure about california but in WA u can swap an engine as long as it is same age or newer than the orignal and retains all emissions parts... but im not sure where your located
