It is currently Sun May 24, 2026 11:08 pm
PostPosted: Thu Apr 19, 2012 1:52 am
http://seattle.craigslist.org/kit/pts/2965535496.html I found this online tonight and need to know, would this work as a donor car? I have a 80 4x4 and just want to swap out rear dif and 4 speed. I've been reading all the forums but can't figure out if the later troopers will work.. Sorry if I'm a slow learner on this subject haha any help would be great!
Cars have no class anymore. so take em to school
PostPosted: Thu Apr 19, 2012 8:13 am
No, look elsewhere. The Trooper has a v6 engine which has a different bellhousing bolt pattern than your 4cylinder engine. You need an MSG (cable clutch) tranny from an '86 or '87 4x4 pickup or Trooper with the 2.3 gas engine- and get the slip joint as well. '88 & newer trucks use an MUA tranny with hydraulic clutch that are physically larger. While the 4cyl version can be fitted to a LUV it's a lot more work, including a body lift for clearance.
As far as rear ends go your truck has 4.10 gears, most Troopers have 4.56 gears. If you change rears you must match the front drivetrain ratio to keep 4wd usable.
PostPosted: Thu Apr 19, 2012 9:45 am
Okkay now I'm gettin it. Thanks so much! Hope I don't get booted to te newbie section haha :D
