It is currently Sun May 24, 2026 10:23 pm
 Post subject: 80 4x4 5 speed questions
PostPosted: Fri Apr 13, 2012 8:10 pm
hey I am new here and i was wondering if there is a 5 speed that will fit in my 1980 luv 4x4 step sidewith the 1.8l engine but i want to keep it 4x4
PostPosted: Mon Apr 16, 2012 6:48 am
'86 or '87 4x4 pickup or Trooper with the 2.3L 4ZD1 gas engine.
PostPosted: Mon Apr 16, 2012 10:08 am
I too have an 80 4x4!.. wish it was stepside though =( anyway ive been toiling with the idea of putting in a 5 speed as well. but from what im reading theres no exact bolt in swaps.
My 4 speed is in good shape so what ive decided to do is just get a little bigger rims to change the gear ratios so im not screaming down the highway (going 50) but if you DO find something that works post it! i may be wrong!
Cars have no class anymore. so take em to school
PostPosted: Mon Apr 16, 2012 1:26 pm
The sources I listed are as close to bolt-in as you will get- it's the same tranny as the stock 4sp except longer & with an OD 5th gear: you have to relocate the support crossmember, cut new shifter holes, replace the slip joint with one that fits the new t-case and lengthen the front & shorten the back driveshafts.
PostPosted: Mon Apr 16, 2012 7:49 pm
i was going to do the trooper trans swap before i picked up a v6.
you can find all of the parts at a yard for a couple hundred, i got quoted aound $70 per driveline for shortening at a shop in portland.
would be worth it for freeway driving, if your planning to keep the luv for more than a few months i would do it
PostPosted: Mon Apr 16, 2012 8:31 pm
k thanks i am not sure if i want put the 5 speed in and get a Weber Canterbury and electronic ignition ect for the 1.8 or just put a v6 in it but for now i need to get some money
PostPosted: Mon Apr 16, 2012 11:48 pm
Carburetor
Users browsing this forum: Bing [Bot] and 31 guests
