PostPosted: Mon Oct 06, 2003 3:30 pm
OK guys I just got my front hubs drilled and welded for 5-lug (4 3/4") car pattern.
They're on but I havent driven the truck yet, the guy says he's done a few sets already.
They weld up the Luv 6-lug pattern and drill new 5-lug one.
The two negative points are:
the new studs have to be welded in place.
you can only use 4 of the 6 bolts to hold the rotor to the hub. (I used locktight)
But otherwise everything seams to be good.
Call "Turbo Machining", Houston Tx. 800-859-5004, ask for Kenneth (the boss I think)
They're a little slow, it took them about 4wks to do my hubs. Cost me $140.
I had to give them the hubs, 10 studs and a wheel - so they can mount it in place, then
weld the studs in place.
74 Luv - 383, 224/224cam, 200-4R, Dana 44 w/373s,
smooth idle "work truck" - 11.30 @ 121.8
67 camaro - 502 street/strip (inthe10s)
