It is currently Sun May 10, 2026 12:17 pm
 Post subject: How much HP can you get?
PostPosted: Wed Feb 01, 2012 5:01 pm
From what i have been reading of this forum and trying to gather knowledge, I have came to a conclusion that if someone want hp out of these little engines, its all in the head. So to try and get some reasoning to my wallet :lol: can somebody give me a rough estimate of how much HP can these engines get by:
1. Port and Polishing a head?
2. Regrinding a Cam? <---- how does one go about this?
I have an 87 Isuzu Pup 1.9L with a 32/36 DGEV, Accel Ignition Coil, and free flowing exhaust ,2.5 Dia pipe, (though I have read that with straight pipe, I may be loosing back pressure, which is needed for torque, is this right?
Thanks,
Marcos
PostPosted: Wed Feb 01, 2012 5:12 pm
These are the people to contact regarding a regrind: http://deltacam.com/
PostPosted: Thu Feb 02, 2012 1:21 am
yes torque is gained with a restrictive exhaust... but not so restrictive that it is the same diameter as stock
as for a port an polish your looking @ 2-5hp and 3-6 foot pounds of torque base line but a port and polish isn't mostly for gaining hp/torque its for the throttle response... gains here are seat of the pants feel imho on this small of an engine but if your going to be raising compression and adding a cam you could see as much as 15hp and 20ft/lbs of torque (over a non polished and port matched head) (p.s. take that high # as a huge guess)
as for a cam i couldn't even tell you or guess
but i don't see with a nice cam grind thats giving you power between 3k-5500, bigger bore pistons, higher compression, a full head job (port/polish/reground valves) why you couldn't get a reliable 130 hp out of one of these for less then $3k
PostPosted: Tue Feb 07, 2012 1:51 pm
Thanks for the feed back guys. This site has a ton of info :D and I am trying to understand of all of it. Well I recently ordered my Offenhauser intake from Mokadeth and will be getting some pacesetter headers soon aswell 8).
Like i said before, from what i have read, if i dont have any back pressure I will loose some torque so since I am running a straight pipe, what kind of muffler would you all recommend?
Marcos
PostPosted: Thu Feb 16, 2012 1:16 am
i have always been impartial to magnaflow but with this truck i will most likely be going a different route.... (there stainless and come with lifetime warranty)
any ways to your problem there is an easy solution to increasing torque run 2.5" pipe to the muffler and run 2.25" exiting out the rear of the truck... or when i finally get around to doing my exhaust i will probably run 2.5" to the muffler and dual exit with 1.75
PostPosted: Thu Feb 16, 2012 10:09 pm
are you still running the stock distributor? the pup electronic one is an improvement over the original one if your looking for a bolt in upgrade.. would work well with the offy, weber, header and cam... kind of the 5th piece of the power puzzle :lol: or the pertronix electronic conversion has been used pretty often with good results
PostPosted: Sat Feb 18, 2012 6:46 pm
Thanks for the replies guys. Yeah im thinking of getting the magnaflow. And love4theluv yes the isuzu pup already has the electronic dizzy which comes stock. I did upgrade the ignition to an Accel. Thanks for the replies guys.
Marcos
PostPosted: Sun Feb 19, 2012 12:26 am
wow i feel slick i completely overlooked that it was an 87 engine
