It is currently Sat May 09, 2026 11:18 pm
 Post subject: suspension
PostPosted: Tue Dec 27, 2011 11:08 pm
1976 chevy luv mikado (stock)
intent is a rodders street truck so drop the front what an inch and raise the rear 2"?
motor swap at a later time (thoughts are) sr20det or sr22det or a 22re supercharged
so what i would be looking for at this point are larger rims (16"), larger disc brakes all the way around, taller gears, lsd (or more commenly posi-trac),and coil overs
i was a racer so the immidiate jump is straight to a irs but budget is kind of low so the intent is a junk yard build so solid axle is probably what its going to have to be
so do i go with a 3-link, or a 4-link rear end to complement the coil
overs?
