It is currently Sun Feb 01, 2026 8:16 pm
 Post subject: higher gear?
PostPosted: Tue Dec 06, 2011 10:06 pm
hi guys! i may be a noob to this site but i have been working with cars for awhile. i have searched this site many times and it seems everyone is doing different things with there trucks and i havent found the exact info im looking for, so hopefully someone will be able to give me some guidence. i have a 1977 2wd luv that i swaped a 2000 chevy vortec v6 with a 5 speed. it runs great but it is way to low geared for the interstate. i recently drove it on its maiden voyge 1000 miles round trip and everything was fine except it would hit the speed limiter at around 67mph. from what i have read on here the truck has a 4:56 gear (i think) and i would love to find a rear gear in the mid 3:xx (dosnt have to be lsd but that would be nice). any info on where i can buy a ring and pinion set or what i need to look for in a junk yard would be great! i and i want to stay 6 lug btw. thanks!
 Post subject: Re: higher gear?
PostPosted: Wed Dec 07, 2011 2:23 am
Australian LUV Guru
Research Isuzu Impulse 3rd member 3.90:1 LSD should bolt in (Here in Australia they do).
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Wed Dec 07, 2011 10:38 am
Fortunately these rear ends are interchangeable through many years, if you read the posts you will find a lot of information. I currently drive an 81 formerly diesel powered Luv, which is a rebadged Isuzu Pup by the way.
And it now has a sbc and 700R4 AOD with the stock 3:42 rear end gears, makes a great freeway flier because with the 700R4 it is turning about 2K at 70!!! In Luvs you have to find a 81-82 Diesel powered on to find these gears, but I understand that some Isuzu Pups also use these, check with Joe Isuzu on this, he knows the Pups inside and out....
Meanwhile just keep reading, I think the highest stock Luv rear ends are limited to 4:11 and what you already have. Good luck, Merry Christmas,
dusty
PostPosted: Wed Dec 07, 2011 12:56 pm
Your stock '77 gears are 4.10's, you had to go back before at least '76 to have 4.56 gears. There are 3rd members out there that will give you a better ratio & will swap right into your axle housing. The stock rear for a '78 LUV w/auto was 3.73, some 2wd 4sp diesel LUV/Pup's came with 3.42's, 2wd 5sp diesel pups had 3.73's. The only LSD sold in the US that will fit a LUV was the turbo Impulse with 3.90 gears, the LSD carrier can be swapped to a different ratio R & P. Look on car-part.com for LUV/Pup's through '87, turbo Impulse '88 & '89 to see what might be available in you area.
PostPosted: Tue Dec 13, 2011 3:13 pm
Ok I found a gu6 (342) option coad rear end from a 81 luv. Will this fit directly into my stock housing with my stock axles? Or do I need to use the 81 axles to?
PostPosted: Wed Dec 14, 2011 6:36 pm
The '81 3rd will fit into your axle housing, if you re-use your axles the axle bearing pre-load should remain the same, if you change axles the pre-load needs to be re-set.
