It is currently Sat May 09, 2026 5:36 pm
 Post subject: What Jets 32/36?
PostPosted: Wed Dec 07, 2011 12:13 am
79 1.8 manual. Can't find any specifics in a search. Truck runs terrible. I just ordered new plug wires, MSD 6AL, fuel pres regulator and a mr gasket timing curve kit. Has new coil, points condenser, and plugs, battery.......................
Thanks
 Post subject: Re: What Jets 32/36?
PostPosted: Wed Dec 07, 2011 1:40 am
Fuel pump?
Just went thru E-dizzy w/ new cap/rotor, wires, MSD 6al & blaster 2 coil, 32/36 w/ return line connected, new alt, VR, batt, fues box cleaning, E-fan pushing, water pump, hoses, stat, dropped pan to check oil pump and timing(rods also while I was there), valve adj., emission removed..., and it was still bogging out when throttle was punched an after 37mph under load. I could ease into the throttle and it would go, but floored or over 40mph bog out... , turns out the fuel pump that was pumping, wasn't pumping enough..., got a old e-pump off of a clean luv at pick a part.
Swapped pumps an all my problems went away. It was nice to have all my upgrades kick in at once..., 70-75 on freeway with no problems.
PostPosted: Wed Dec 07, 2011 3:16 pm
viewtopic.php?f=5&t=19630&p=142884&hilit=jets#p142884
