It is currently Tue Jun 30, 2026 5:08 am
 Post subject: drive shaft?
PostPosted: Tue Oct 01, 2002 11:30 am
I'm going to use the stock rearend in my luv after I install the 350/350 combo. What drive shaft can i use? Can I use the camaro drive shaft like you would use with the S-10 rearend? Any suggestions would be helpful. Rusty
PostPosted: Tue Oct 01, 2002 4:25 pm
You will have to have one custom made. There isn't any driveshaft out there that will mate up at both ends. Any driveshaft place can fab you up one if you take your luv shaft and a yoke for the 350. I think mine was around $165 to make. You will also need the measurement from center of front u-joint to center of rear u-joint for the length of the shaft.
PostPosted: Tue Oct 01, 2002 7:14 pm
I'm really glad I found this site! I'd be lost without it! Thanks for all the help. There's too much LUV on this site!
Users browsing this forum: Bing [Bot] and 30 guests
