PostPosted: Sun Sep 07, 2003 8:47 pm
My 79 LUV has a lot of rust in the frame and a very worn out steering box which I can't find a replacement for.A friend of mine has a complete S-10 4x4 frame with all the driveline I can get for $100. Anybody ever tried this?
PostPosted: Sun Sep 07, 2003 10:54 pm
with a cutting torch and a welder all things are possible :wink: :D
PostPosted: Wed Sep 24, 2003 3:51 pm
actually, it will fit, without a torch. a guy in my town put a s-10 bed on his luv and it fit fine. the only difference in the frame is its a c frame and a luv frame is solid.
PostPosted: Sat Sep 27, 2003 5:29 pm
Great!That's what I was hoping for.I thought I might even drop in a small block and TH350 while I'm into it.
 Post subject: Luv to s-10 frame
PostPosted: Sun Sep 28, 2003 11:35 am
You will have to cut and move some of the mounts for the cab and radiator supports, they are to wide to match up. Plus you will have to make a adapter to hook up steering linkage to steering wheel. :)
PostPosted: Thu Oct 02, 2003 7:01 pm
That doesn't sound too bad if that's the worst problem I run into.
