It is currently Sun Jul 05, 2026 11:41 pm
PostPosted: Mon Jan 03, 2011 8:42 pm
So I found out I'm not moving overseas until August, so I don't need to worry about selling the LUV at the moment; will reconsider that later.
Therefore, the Impulse 5-speed and 3.90 rear end are getting installed. I need to know which way I need to go with the clutch kit, though... I'm assuming it would just be the standard G180 clutch kit, correct? Is there another model I can use one from (complete kit if possible) that's a little more heavy duty so I have a stiffer pedal? My clutch is really soft, not to my liking.
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Mon Jan 03, 2011 8:55 pm
The 4x4 is a slightly bigger clutch and i think it is the same as the 2.3 and maybe the 2.6 but not sure.To use them you will also need the 4x4 flywheel.
PostPosted: Mon Jan 03, 2011 9:03 pm
Don't want to get too financially invested in the swap with exchanging flywheels, as well. Anyone have experience with the 1.9L kits? Possibly the one for the higher hp Impulse G200?
PostPosted: Mon Jan 03, 2011 9:37 pm
i have always been told if you do a 5sp use the G200 kit as it is bigger... that is what i have to put on my isuzu gemini
PostPosted: Tue Jan 04, 2011 8:38 am
Pez, are you gonna need a slip yoke--or do you have one already?
PostPosted: Tue Jan 04, 2011 9:12 am
I have one from the first time I was installing, thanks though!
Do you need to swap flywheels for the G200 clutch kit as well or can I stick with my stock one?
PostPosted: Tue Jan 04, 2011 11:52 am
i am using the G200 flywheel also... if i remember wright the g200 clutch didnt bolt to the g180 flywheel
Users browsing this forum: Bing [Bot] and 45 guests
