 Post subject: 4 link
PostPosted: Sat Aug 30, 2003 3:40 pm
Can anyone tell me how i can put a 4link in the front and back because i wan to put full size 12 bolt axels under it and get massive lift
PostPosted: Tue Sep 02, 2003 2:21 pm
Japanese Redneck
not sure if 4 link on the front is what you want. There will be clearance problems especially in the front with the upper links. you can put massive lift on a truck that has leaf springs on it or better yet... some fox coilover shocks.
PostPosted: Tue Sep 02, 2003 3:12 pm
If your looking to do that kind of suspension, 4 link will be just fine in the rear but you should use 3 link with coil-over in the front.
