It is currently Tue Jul 07, 2026 3:17 pm
PostPosted: Sun Sep 05, 2010 8:33 pm
Is a s10 rear end the right length to just bolt right into a luv? I don't have a s10 to measure, I have a set of draglites that are 5 lug that I want to use and I am trying to figure out the cheapest and easiest way to convert the rear to 5 lug.
Also the length rear end what back spacing do I need for 15X8 wheels? If I had a rear to measure I wouldn't need to ask this but I figured some one on here has allready been down this road
PostPosted: Sun Sep 05, 2010 8:40 pm
A dime rear is about 4 inches wider, so you need to figure your back space with that in mind...
PostPosted: Mon Sep 06, 2010 5:32 pm
I just picked up a 94 dime which is 54 hub to hub perches are about 3/16 to a 1/4 wider thats rough measure mind you 3:73 better than 4:10 add 15" tire lower RPM Add V-8 FUN!!!!! :esurprised
Enjoy, The mouse trap is comming!
PostPosted: Thu Oct 21, 2010 2:05 pm
Could you leave the s10 rear end the way it is and run wider tires that stick out a little bit?
PostPosted: Thu Oct 28, 2010 6:44 am
i put a 2000 s10 rear end in mine and narroed it 2 1/2 iches on each side and it fit like stock
Epic Fabrication.
KAOS
PostPosted: Thu Oct 28, 2010 10:51 am
I used typhoon rear and it was only a 1/2" wider at wheel mount surface than the stocker.
dropped right on the perches too.
A.j.
PostPosted: Mon Nov 01, 2010 5:25 am
s10 perches lined up to was jus bareley out the fender wells...
Epic Fabrication.
KAOS
