It is currently Sun May 24, 2026 11:50 pm
PostPosted: Sat Oct 16, 2010 9:36 pm
between rear gear ratio. i still need to be able to drive on the street but on the highway i dont want it to be screaming, for all street id go 3.73 and all race would be 4.11. so would 3.89 is what im thinking. in a ratio calculator it puts me 200 rpm below 3000 at 60mph. im fine with that. but how will 3.89 do at the track? am i going to lose quite a bit in the 1/4 mile?
PostPosted: Sat Oct 16, 2010 10:03 pm
How can anyone answer this without knowing what you're driving?
PostPosted: Sun Oct 17, 2010 2:35 am
There is not enough difference between 4:11 and 3:89 to make the swap the least bit worth the effort...
PostPosted: Sun Oct 17, 2010 5:50 am
setup is sbc383, th350, 9 inch rear. the 9 inch isn't built yet thats why im trying to figure it out so i only have to do it once instead of switching out the R&P
PostPosted: Sun Oct 17, 2010 10:59 am
Tire Dia. is needed.
PostPosted: Sun Oct 17, 2010 11:16 am
Not knowing what the tire size is, my experience is the best compromise for street and still being able to get off the line is a 3:50 gear. Also to fine tune it you could run a taller tire on the street for the best highway rpm and something with a lower profile for the strip. In my 63 stepside I ran a 350/turbo350/3:42gear and 275/60/15 tires and it could cruise at 70 and still light up the tires pretty good off the line with a nice chirp into second.
PostPosted: Sun Oct 17, 2010 12:49 pm
I'll be running a 28-29 inch diameter tire.
PostPosted: Sun Oct 17, 2010 8:18 pm
A 29" tire will turn 695.45 revolutions per mile.
Multiply that by the gear ratio to give rpm's at 60mph with a 1:1 high gear.
PostPosted: Sun Oct 17, 2010 10:46 pm
Exactly....I have run several different gears in mine. There is no "perfect" set up for street/strip. On the hiway there is minimum change in RPM at hiway speed unless you are changing a full 1.0 in gear change....but a nice thing about a 9" is up can swap chunks and have several ready to stick in if nessary....
PostPosted: Mon Oct 18, 2010 10:49 am
whats your induction?
whats your converter stall?
whats the trans built like?
suspension?
all factors for choosing gear, especially if your trying to be competitive.
for the average joe schmoe build? a set of 3:42 to 3:73s are the most fun on the street.
A.j.
PostPosted: Mon Oct 18, 2010 5:43 pm
whats your induction? 770 holley, dual plane weiand stealth air strike
whats your converter stall? 3000-3200
whats the trans built like? th350 hardened intermediate sprag, hardened intermediate roller
suspension? stock rear springs with caltracs and stock front suspension, will be changed to coil overs soon
PostPosted: Mon Oct 18, 2010 7:37 pm
I must be missing something here as from what i read is you want a street rig that you can drag race to right?
Chances are you will be bracket racing anyway so set the rig up for the street (i would use 3.50s with the 29" tires)and enjoy in will still be fairly quick and then change gears as you get closer to just drag racing .Then you must pick the gear for your tire size and rpm at the stripe.
There are so many variables that these are just suggestions for you to ponder.
