It is currently Mon May 25, 2026 8:14 am
PostPosted: Sat Aug 21, 2010 9:33 pm
Depending on it my 4ZC1-T front clip sells I may end up parting the motor out. I've been asked the question, and read some conflicting info, so I figured I'd ask and get a definitive answer...
Do 4Z (2.0, 2.3, 2.6) intake and exhaust manifolds bolt up to G180/G200 engines?
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Sun Aug 22, 2010 1:06 am
Not sure about the intakes, but 4ZD1/E1 exhaust ports are round, G180/200 exhaust ports are square, even if they physically will bolt together they won't work correctly.
PostPosted: Sun Aug 22, 2010 4:08 am
Australian LUV Guru
Inlet manifold will interchange but there is a water gallery that needs to be either opened up or blocked.
1980 4x4 KBD40 ISUZU/Chev Luv
