It is currently Mon May 25, 2026 4:24 am
 Post subject: Differential question
PostPosted: Mon Jul 12, 2010 12:41 pm
Picking up my parts car this weekend so I'm gathering a couple of items from the store. I was able to pick up a front/rear yoke from a 2.3 5-speed to go on my driveshaft to mate everything up, but I'm curious if I will even need to change the rear yoke out?
The 3.42s I have now are from an '84 and the driveshaft mounted up without modification, will it mount up to the 3.90 from the Impulse the same way or will I need to swap the rear yoke for it?
And if I DO need to swap the rear yoke, do I use the rear u-joint for the '76 or one from the '87? The '76 only has one part number for front/rear u-joints on advanceauto.com (1-0300) but the '87 has a separate number for the rear (2-0383).
1-0300 link:
http://shop.advanceautoparts.com/webapp ... 1345635___
2-0383 link:
http://shop.advanceautoparts.com/webapp ... 1390596___
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
Users browsing this forum: Bing [Bot] and 23 guests
