It is currently Tue May 26, 2026 2:53 am
PostPosted: Sat Jul 03, 2010 11:50 am
Question... I need to swap the shift lever on the '87 impulse 5-speed going in my truck and I have the shift lever from a '90 Pup and I believe it was a remote shifter. Anyone know if this is going work or do I need to go return it?
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Sat Jul 03, 2010 6:32 pm
I'm not sure if I understand your Q. Does the '90 truck part have a remote shifter? I know the RWD I-Marks shift lever is located about 3"-4" forward of the automatic lever. When changing over from auto to standard it requires cutting a new hole in the center tranny tunnel/"hump" forward of the existing opening and sealing the original (the cutout piece is great - already conforms to the curve). A common complaint is smacking your knuckles into the dash going from 2nd into 3rd. Ctmandu told me he just bent his shift lever to a more comfortable location. I believe some Impulses had a remote shifter and if you don't want it, I do! I'll even drive over to pick it up! As to your Q, try to test fit and see how close it looks.
_________________________
83 Isuzu I-Mark 1.8
01 Saturn L300 V6
PostPosted: Sat Jul 03, 2010 6:49 pm
I'll try to clear up what I was asking, lol. The '87 Impulse 5-speed has, obviously, a car's shifter which is too short and so I need the shifter from a 5-speed Pup. I know that the transmissions changed after '87 to the MUA transmissions and the shifter I picked up is from a '90 Pup.
So... will a '90 Pup shift lever work with an '87 Impulse's 5-speed?
PostPosted: Tue Jul 06, 2010 12:58 am
is the 90 truck a 2.3L 2.6L or 3.1L V-6 :?:
gota be a 2WD with 2.3L to be the same trans.
the 2.6 and 3.1 have the MUA
1988 up the 2.3L is a 2WD only engine with the older MSG.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Tue Jul 06, 2010 3:55 pm
That's a great question... I need to go back and verify what 4 cyl it has. It was about to rain on me and my buddy the day we went, so I was in a bit of a rush.
Thanks Trooper!
