It is currently Tue Jun 30, 2026 5:55 pm
 Post subject: TURBO CHARGING A 1.8
PostPosted: Tue May 18, 2010 10:05 pm
ANYONE downunder ever turbocharged one? got a turbo and want to know if i put the carb on the vaccum side of turbo do still need a blowoff valve?. any help would greatly apprechiated.also wondering about putting the turbo under the bed.have a pertronix ingition /msd setup with a 32/36 weber setup.bore .75mm got a sbc leftside header on it. Was thinking 4-7 psi .
 Post subject: Re: TURBO CHARGING A 1.8
PostPosted: Thu May 20, 2010 11:57 pm
The blow off valve is to prevent the turbo compressor from surging and stalling when you close the throttle plate under boost, so yes, it's needed.
If you're going to run a rear turbo setup, where are you going to put the carb? If you put it at the front, you're going to have fuel travelling all the way from the turbo and back, which can cause it to pool, and be a fire hazard.
I don't think doing this with a carb is a good idea...
1975 Project LUV
It's ALIVE!
PostPosted: Sun May 23, 2010 12:48 am
blow through or EFI would be the go for a rear mount turbo set up.
PostPosted: Sun May 23, 2010 1:54 pm
sleeps at LUVTruck.com
I'm curious.....would it be safe to do this if the turbo was mounted in the engine bay?
PostPosted: Mon May 24, 2010 12:50 pm
there is a e-bay for turbo kit for the LUV from $299- $1800 anybody know of any one using this set up
PostPosted: Tue May 25, 2010 12:03 am
I havent done this myself, but it seems like a simple solution would be to strip down a turbo impulse and either use the impulse motor or use the parts on your block. I would think it is pretty much a direct swap other than if you have to figure out the computer wiring if it has one.
PostPosted: Sat May 29, 2010 10:53 am
I am also looking for some info about the same subject, i was about to order the turbo from ebay but I stoped myself since I had many question about doing it on a carburated engine, I have seen it before I dont know what do I need, any help?
PostPosted: Wed Jun 09, 2010 9:58 am
first off, you will need to convert to a 4bbl or weber style intake... something that will accept carbs for blow through operation.
I can fill you in on all you need to know about it....but it wont be an easy quest to make the power you want with the 1.8... aftermarket support is slim and overseas parts are expensive.... I dont see it being worth the money or time (i traveled this verty road not to long ago.) on it...
A.j.
