It is currently Mon Jun 29, 2026 12:10 pm
 Post subject: restricted oil
PostPosted: Wed Aug 28, 2002 9:47 pm
:twisted: i would like to get your thoughts on oil restrictors for the top end for street & strip. it will probably see only lite street duty if at all. i`ve never messed with restirictors before. so give me some info so i can make a wise decision. thanks terry :crazyeyes:
PostPosted: Wed Aug 28, 2002 10:56 pm
you need to talk to your engine builder -depends on oil pressure ,rpm ,
engine {sbf sbc bbc bbf}some dont need oil restion to the top, some do,
if you dont have an engine bulider than buy a performace book for your
engine
PostPosted: Thu Aug 29, 2002 9:25 pm
:twisted: i`m doing the build myself. its an sbc with solid roller cam. i`ve talked with some people at the track.some swore by them others swore at them. i just thought i would get some more opinions. thanks terry
PostPosted: Thu Aug 29, 2002 9:57 pm
i have done a few engines and the only one i restricked the oil to the top
was a ford 390 block that was 415 ci ,the things i would do is to use
screens in the rocker valley and heads {to keep small parts from the oil
pan} and check the lifters to see if the oil holes match the block channel
hope this helps
