It is currently Thu Jun 25, 2026 8:41 am
 Post subject: A few Questions
PostPosted: Sun Aug 20, 2006 8:31 pm
The SBC swap is almost complet, but i have a few final questions. 1) Is there a way to fit the stock speedo cable to a turbo 350 tranny 2)What stock radiator hoses (top and bottom) fit well with lest modification (I have the Howe 19 X 22 radiator) 3) I plan on keeping the stock rearend for know since my wheels and tires are new, what drive shaft do you reccommend (stock or camaro) and how does it need to be modified. Thanks for any help.
PostPosted: Sun Aug 20, 2006 8:45 pm
i hear the simplest driveshaft to use is one from an automatic equipped luv as the yoke fits the th350 and the rear obviously fits the rear axle....
PostPosted: Mon Aug 21, 2006 8:56 am
I used a universal 1 1/2" x 15 top hose , but have no found a bottom hose.
I'm also looking for the answer to the speedo cable question.
I bought the front half of a camaro driveshaft and the rear half of a ford truck as my truck has a 9" ford. I plan to trailer the truck to the driveshaft shop and let them build it to fit. I would have to agree the factory auto shaft would be the easist fit, but finding one will be fun.
Good luck and I feel your pain.
