It is currently Mon Jun 29, 2026 7:40 pm
 Post subject: SBC questions
PostPosted: Fri Jan 22, 2010 11:59 am
okay so im needing to buy roller rockers, hydrolic roller lifters and pushrods...and i am totally lost about all of this. my motor is a 010 sbc 350 bored 30 over. i dont know what length of pushrods i need and what roller rocker diameter and ration i need nor do i understand what those mean. ive tried searching but im so frustrated with it i just wanna have something laid out so that when i goto buy them i knnow what im looking for. thanks
 Post subject: Re: SBC questions
PostPosted: Fri Jan 22, 2010 3:08 pm
Most sbc cams are ground specd for a 1.5 rocker, if you get the correct cam, that will be the rocker to use. Bigger ratio rockers will make the cam seem bigger, but if you buy properly, no need. Pushrod length ideally will be determined at mockup, that way you get the correct length. Decide on the cam manufacturer you want to use, then talk to one of their techs...
