It is currently Mon May 25, 2026 1:23 am
PostPosted: Thu Oct 14, 2010 9:39 am
The donor is a 1978 2-wheel drive, and the project is a 1980 4x4. Are there any problems with this swap? What should I keep from the original motor?
Thanks, 80luv4by4
PostPosted: Thu Oct 14, 2010 11:22 am
The oil pan, other than that, it should drop in...
PostPosted: Fri Oct 15, 2010 1:15 pm
If you are putting the engine into a 4x4 you must use the 4x4 oil pan- the drain plugs are on opposite sides, you'll dump oil onto the front differential during a change with the 2wd pan.
