It is currently Sun Jul 05, 2026 7:12 am
 Post subject: Ratios?
PostPosted: Tue Dec 22, 2009 5:44 pm
i want to know all about ratios.
like ppl say 3.31s in an axle or something idk what that means?
1980 chevy luv 4x4
 Post subject: Re: Ratios?
PostPosted: Tue Dec 22, 2009 7:07 pm
The ratio number is the number of driveshaft turns for 1 revolution of the rear wheels.
So on an axle with 3.31 gears, the driveshaft will turn 3.31 revolutions per 1 revolution of the rear wheels.
PostPosted: Tue Dec 22, 2009 7:09 pm
Also note that when people talk about "lower" gears, they are referring to a numerically higher ratio. When they talk about "higher" gears they are referring to a numerically lower ratio.
To some, this seems backwards and is often the source of confusion.
PostPosted: Wed Dec 23, 2009 12:42 am
thank explains it all! :D thanks man
1980 chevy luv 4x4
PostPosted: Thu Dec 24, 2009 2:02 am
wait so what kind of ratio would be good for more power or for a little offroadin and still a daily driver?
1980 chevy luv 4x4
PostPosted: Thu Dec 24, 2009 8:06 pm
Your '80 LUV has 4.10 gears, the only gearing upgrade is 4.56 gears from '84-'87 Troopers (except the '87 turbo diesel). The rear third is an easy swap, the front is a major operation.
Do a search for engine power upgrade options.
PostPosted: Thu Dec 24, 2009 11:30 pm
alrighty
1980 chevy luv 4x4
