It is currently Sun Jul 05, 2026 6:02 am
PostPosted: Sun Nov 29, 2009 3:36 pm
Hi all, I keep trying to search but the search engine keeps omitting "3.42".
Basically what I'm trying to prepare for is a TDi swap down the road and I want to install a 3.42 so I can get better mileage right now and keep the RPMs low for the diesel after I install an R154 5-speed. I'm not going to bother purchasing and installing a LUV/PUP 5-speed because I would just be removing it again, anyways.
Was there a specific model/engine/trans combination that they were available on so I can narrow the search?
Also, I have to replace a lot of trim pieces. The rubber has all rotted away and I don't want to have any moisture issues. This is for a 76' model 2x4.
I found these on partstrain, but it's one of those websites where the pictures are all generic:
http://www.partstrain.com/ShopByDepartm ... VROLET/LUV
Basically, I need to replace ALL of the rubber trim in the doors and would like to buy a complete kit if they're sold. I saw posts about restoration specialties and P/N 990021 but I don't think it's all I need, which is basically everything in this pic:
Also, the rubber seals on all of my signal lamps (front/rear) are all crumbling. Are these even available or should I just get no lamp assemblies?
Still waiting on my weber to get in, so I'm tending to the other odds and ends. Thanks in advance, all!
1976 2x4 LUV: 4-speed, 32/36 Weber, desmogged, 3.42 gears
My '76 LUV and Impulse 5-speed for sale:
viewtopic.php?f=8&t=24576
PostPosted: Sun Nov 29, 2009 7:25 pm
1984 gas with 4spd was a special fuel saver model with a 3.42 rear. Try car-part.com, axle assembly rear, it will ask for the ratio & give salvage yard sources in your area.
PostPosted: Mon Nov 30, 2009 9:29 am
I don't know what gear ratios are in the R154, but if the first gear is much higher than the stock Isuzu 5-speed, you might not want a 3.42. I have the Isuzu 5-speed and the 3.73 diff that always came with that transmission. At 65 mph, I'm turning ~2,700 RPM, which is no sweat. I've buried the 85-mph speedometer (probably about 90) and still wasn't at the 4,250 RPM redline. I'm assuming the TDI is a higher-revving engine than my C223, so I'm thinking the 3.73 may be perfect for you. And it's MUCH easier to find than the 3.42, since it came on every 2wd 5-speed P'up.
Edit: I found a photo, courtesy of "graydonblair" at the IsuzuPup.com forum. This one is with the speedo pegged at 85 mph. (Kids, don't try this at home!)
P.S. - I'm pretty certain his steering wheel is NOT indexed to point straight when the truck is going straight! :lol: Turn the wheel that much at 85, and it's doubtful whether you'd be around to post photos!
PostPosted: Mon Nov 30, 2009 8:58 pm
If your still hunting a 3.42 get on isuzupup.com and ask for Jerry he'll know, bought mine from him.
PostPosted: Mon Nov 30, 2009 9:11 pm
Well, the TDI has it's peak torque at ~1750rpm, and that's where I'd like to get close to when cruising at interstate speeds (70-75) and highway (55).
For example:
With a 3.42 rear, 27" tire height (just a guesstimate) and a .753 final gear ratio (R154 5th gear) I would turn 2404 rpm @ 75mph and 1763 rpm @ 55.
So around town I would almost be at my peak efficiency, so it should return some great mpg. The 3.73 would add an additional ~200 rpm anywhere in the band, which wouldn't be optimal. If I spent a fortune adapting a T56 it would be a non-issue with its .5 final. lol
Was the '84 the only available year for that diff?
And anyone have a clue about the window trim?
I'll hit up isuzupup.com for some info as well for the diff. Thanks smokey!
