It is currently Sun Jul 05, 2026 6:40 pm
 Post subject: Transmission cooler
PostPosted: Sun Jan 16, 2011 11:59 am
Well, I did a search on this and only 14 results came in as my 19 x 22 has no provision. I was going to run a 22" aluminum single pass. Is any one running this on the street or similar set up. Is your cooling OK are you running 2 one on each frame rail? the weight is light on the LUV so I think this will be OK. Getting real close to starting the build only have a few more parts to obtain then it's wrench time. Should be a hot engine for a 64 250hp 283 when it was new. Made a few upgrades in it, good for the street anyways. OOps put this in the wrong area. :oops:
Enjoy, The mouse trap is comming!
 Post subject: Re: Transmission cooler
PostPosted: Sun Jan 16, 2011 7:08 pm
Wow Thats cool it got moved Thanks!
PostPosted: Sun Jan 16, 2011 8:55 pm
You're welcome. :)
PostPosted: Mon Jan 17, 2011 6:43 pm
8)
