PostPosted: Fri Oct 09, 2009 10:20 am
im looking for a turbo for my stock 1.8l motor i would like and a turbo . im not sure if i can do this yet but i think it will work.i can use all the help i can get on this so let me know if you have anything to help me with this.i know that someone on here has used one or is using one .
PostPosted: Sun Oct 11, 2009 11:35 pm
theres a bloke here in australia that does them, pretty sure hes on this forum, his user name will be something like gemini racing i think im pretty sure his names darren.
PostPosted: Sun Oct 11, 2009 11:38 pm
heres his thread on ozgemini
http://www.ozgemini.com/forums/non-tech ... .php?t=138
PostPosted: Mon Oct 12, 2009 3:13 am
Australian LUV Guru
Turbo + Stock Motor = BANG!!!!!!!!!!!!!!!!! :lol:
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Oct 12, 2009 9:27 am
:signiagree
PostPosted: Mon Oct 12, 2009 11:32 pm
lotsa $,lotsa work! but if youve got the time n cash it will be quite the sleeper 8O
76 mikado project,mean green
PostPosted: Tue Oct 13, 2009 1:00 pm
well what do you mean bang bang ass in i will be blowing my motor or what ? i just want to get as much power out of this thing as i can. i just bought a brand new stock motor and i am wanting to do something with the old one to get max power out of it i have heard about guys with turbo on the g180 and g2 or something like that help e out yall know im new to this lol
PostPosted: Tue Oct 13, 2009 4:08 pm
Hello, This will be a great engine to turbo, BUT there are a couple of items I'd like to pass along to you. I am like Ol Rob, I've been around a few years and back in the 70's I owned a turbocharging facility in Las Vegas. We contracted with Fletcher Jones Chevorlet to sell Turbo'ed Chevy's with a warranty!!
Anyway we had great luck with the V8s, but had a severe head gasket problem with the stock 1.8s.
1, First of all replace the stock head bolts with at least a grade 8 bolts, sometime you have to install extra washers to get just the right heighth, check with your local speed shop, perhaps you can find some from another engine that will work, this I don't know. The stock head bolts stretch under boost.
2. Be sure to torque the bolts down extra tight with the new bolts, at least 10 lbs over stock with clean well oiled threads.
3, Buy an adapter to use a "Pinto" upright type Weber 2300 model 2 bbl carburetor to use, the stock one just doesn't work well, you will doing away with most of the vacumn lines anyway.
When you get the Weber 2 bbl, this is a progressive linkage carb by the way, check with a carb guru and he should be able to show you the lead ball blocking off the power enrichment passage. Remove this lead ball, install a short piece of copper tubing in its place and route this line to a true engine vacumn-pressure source. (Behind the turbo) This is because you want the carb to get a true reading of how much air is going into the engine.
4. Also be sure to use a water injection system that will spray water, or better yet a alcohol-water mist when the engine is under boost.
There are several of these systems available, some work on a simple pressure switch that turns on a windshield washer pump connected to a bottle, others are compete computerized systems, check them out.
4. Use a waste gate, do not use an IMCO pressure reducer to control boost, if you want to go over 7 lbs, use an intercooler, you want to keep the intake air as cool as possible. And an IMCO type pressure reducer builds heat into the intake charge.
Just a final note, the Toyota 2.0-2.2 engines were really great engines to turbo, a stock 2.0 would put out about 85 HP to the wheels, while a turboed one with 6 lbs boost would easily put out 175 HP!!!
We actually were able to pull 345 HP from a Colt 1600 CC engine on a dyno! And we ran it for several hours with no problems! (With about 21 lbs of boost)
Most of the crossflowed engines like you have will respond quite well, with under 7 lbs boost, above that, ????
Remember a stock 1.8 will displace 1.8 CCs at sea level-14.7 psi pressure(assuming 100% volumn metric efficiency) while with 7 lbs boost you will have increased the volumn to approsimately 2.8 CCs!
Always work with absolute pressure-not just boost!
Know I got long winded, but hope this will help, don't hesitate to contact me if I can be of further assistance.
dusty scjconv
PostPosted: Tue Oct 13, 2009 4:43 pm
thanks man i did all the help that helped me more than anyhitng has so far keep it coming so what do you think a build like this will cost when its all said and done motor wise that is?
PostPosted: Tue Oct 13, 2009 6:01 pm
Glad you were able to decipher my message. I suggest you search the net and find a supplier, then you can order the carb adapter and the turbo plus a flange to mount the turbo to your stock exhaust manifold, or there is a site posted on LUV truck.co where a man in Australia sells the complete exhaust system.
As far as cost, I'd think you could get everything for around $800. or so
dp
PostPosted: Wed Oct 14, 2009 9:18 am
if you got the money I got the time.
Contact me for a fully assembled turbo motor.
I have a spare 79 engine. ... complete.
A.j.
PostPosted: Wed Oct 14, 2009 9:03 pm
here is an article i have on doing it....
http://www.luvtruckin.org/resources/turbo.pdf
PostPosted: Thu Oct 15, 2009 9:38 am
Sooo bitchen, that is a way cool article! i love how its an old skool draw thru unit!
awesome find Ctmandu!
A.j,
PostPosted: Thu Oct 15, 2009 9:44 am
thank you... i do have more how too's for the luv on my site . take a look... almost all are on the luv but i think one or two are not but at least it gives you the idea on how to do certain things
http://www.luvtruckin.org/how-tos.php
PostPosted: Fri Jun 25, 2010 12:41 pm
hey ctmandu i just tried the link and nothing came up...
PostPosted: Fri Jun 25, 2010 7:09 pm
sorry i moved it to my new site...
you will find it on this page of my site...
http://www.luv-truckin.com/SearchResults.asp?Cat=24
