It is currently Mon May 25, 2026 3:42 am
PostPosted: Sat Jun 13, 2009 1:35 pm
will the 85-93 rear end fit the luv. how much wider is it. try search but could not find what i wanted. Also does anyone have a t5 manuel trans for sale I need one. thanks
1975 luv daily driver.
Project-soon to be revived
PostPosted: Sat Jun 13, 2009 2:20 pm
It has been used on trucks.
http://forums.luvtruck.com/viewtopic.php?f=6&t=17072&hilit=S10+rearend
More posts than that one, but it should give you what you need.
PostPosted: Sat Jun 13, 2009 5:32 pm
thanks that helps
PostPosted: Mon Jun 15, 2009 8:09 am
which model of T5 are you after?
have 4 forsale.
A.j.
PostPosted: Mon Jun 15, 2009 10:49 pm
chevy 5-speed Borg Warner T5 manual from the s10 or the camaro, around 1982-1993. not the ford t5 :smt009. now that I think about it the s10 t5 would be better cuz of the shifter location. the camaro is closer to the tail shaft. but ether one i can get my hands on will be great :D .
PostPosted: Tue Jun 16, 2009 7:56 am
the S10 t5 is in the correct shifter location, but wont handle much power. ive blown 3 with the stock 4 cylinder and a little nitrous.
what you need to do is get a camaro V8 trans and swap the tailhousings. depending on what engine your going to bolt it up to that will determine the clutch pack.
do you want a core trans? or a complete built one?
A.j.
PostPosted: Tue Jun 16, 2009 8:18 am
its going in to 2.2 ecotec motor. the bell housing coming from quad4rods. and yes the complete built trans. is the camaro input shaft have the same spline count as the s10 input shaft. cuz i can use the flywheel and pressure plate from the ecotec and then use the clucth disc from a 80's buick quad4 motor cuz this has the same spline count as the s10 t5.
PostPosted: Tue Jun 16, 2009 3:41 pm
Someone needs to make something where a T-5 Ford transmission can be used. They are much easier to find. I think the input shaft is too long.
PostPosted: Tue Jun 16, 2009 6:54 pm
that is true on craigslist the ford t5 is everywhere but it is longer and the spline is different aswell. hope i can fine one soon so I can make the mounts and see how much Clearance i need and so forth.
PostPosted: Wed Jun 17, 2009 7:17 am
no there different. the camaro has more.
A.j.
PostPosted: Wed Jun 17, 2009 2:11 pm
well I got to find the s10 t5 or see what would work with the camaro t5. Or I could get the adapter plate for the 200r, some one makes it just cant remember who.
PostPosted: Wed Jun 17, 2009 7:58 pm
whats the bellhousing patteren that you need?
is it the 60* patteren?
as for clutch, i have a part number for a 9" clutch that will fit the camaro input shaft, but is small enough to still fit under 60* bellhousing. its an adapted unit I found while swapping a camaro t5 into my S10 for the added strength.
A.j.
PostPosted: Wed Jun 17, 2009 10:40 pm
here is the bellhousing I will be getting if I can get a t5
Im going to call the guy over at quad4rods and see what would work with the camaro t5
and thanks, dr_frankenstein56 and, Papa G for all your help.
dr_frankenstein56 I'll get back to on that part #. thanks
PostPosted: Fri Jun 19, 2009 7:53 am
Another T-5 that works is the one in a Astro van and they must be of the V8 style as a friend of mine has one behind a 455 Olds in his 67 442. Just something to look at.
PostPosted: Tue Sep 22, 2009 5:00 pm
i know this is kinda an old thread, i stumbled upon it looking for 5spd info
just thought i would throw this in here, i had a v8 s10, had a 305/t5 in it, the tag on the t5 said it came outta a 93 2.5l 4cyl, and i drove this thing HARD!!...never had any shifting issues when i would turn it 8000 rpms, side stepped the clutch several times, went 14.38 @ 98.02 with a 2.3x 60'
it used a bellhousing/slave cylinder off a late 80s early 90s fullsize v8 truck, the tranny would bolt right up to the bellhousing with a 3/4-7/8" spacer between the two, worked perfect
just your average bagged v8 mini truck
PostPosted: Wed Sep 23, 2009 1:16 pm
8000rpm on a 305?
A.j.
PostPosted: Wed Sep 23, 2009 4:26 pm
lol yea, it was WAY over cammed, stock heads, stock valve springs, torker intake and a 600 vacuum secondary holley, i bought the truck the way it was, i drove the crap outta it, i couldnt kill that damn thing, i tried ALOT, i sold the truck and it still runs with the same motor to this day :D
PostPosted: Wed Sep 23, 2009 8:20 pm
Has anybody checked Trans Dapt to see if they have an adapter to bolt in the Ford T-5 ?
PostPosted: Thu Sep 24, 2009 12:33 am
well not really sure but I think they do. check it out.
http://www.transmissionadapters.com/index.htm
http://www.transmissionadapters.com/Pricing.htm
Users browsing this forum: Baidu [Spider] and 17 guests
