It is currently Mon May 25, 2026 1:24 am
PostPosted: Tue Sep 01, 2009 11:37 pm
Just wondering if any Luvs, Isuzus came with a locking rear end, and if so, what models. I have a 81 formerly diesel powered Luv with 3:42 gears. It is now powered by a sbc 305 w/ a 700R4 AOD and I love the gear set up, just wish it was a posi traction (locking) type.
Thanks scjconv
PostPosted: Wed Sep 02, 2009 5:44 pm
Contact Independent4x, they are building 10-bolt Isuzu fronts with Impulse LSD's, don't know why they couldn't install one into your rear.
The 10-bolt Aussie Locker will fit your rear, but the thrust block that adjusts the axle bearing preload can't be re-used. I had a custom thrust block machined to fit within the locker on each of the Aussie's I'm running, axle play was returned to stock. They are a little noisy but work great.
PostPosted: Wed Sep 02, 2009 6:54 pm
Thank you for this great information, seems the boys down under have a lot of stuff we can't or didn't know about.
I'll do some more checking.
scjconv
PostPosted: Sun Sep 06, 2009 6:57 pm
the Impulse is it, unless you do a major swap to the newer 12 bolt rear.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
