It is currently Tue May 26, 2026 7:42 am
 Post subject: gmc 153 2.5l 4 cyl
PostPosted: Sun Jul 26, 2009 2:41 pm
heard this will work in my luv?
its from 1965 but is completely remanufactured with a reman 4 speed trans also for 1800 bucks.
sounds like an alright deal for some pretty good power?
let me know if this sounds right
 Post subject: Re: gmc 153 2.5l 4 cyl
PostPosted: Sun Jul 26, 2009 7:17 pm
Not a direct bolt in but would be an easy conversion to do and you can put a T-5 in it later for the overdrive.
Oh and there is allot of speed goodies for the 2.5/3.0
PostPosted: Sun Jul 26, 2009 10:58 pm
This is a very strong engine, been around a long time, in Jeeps, and GMs
There is lots of information on the web about it. This is basically the same engine used in the Buick Grand National cars, although it was beefed up for the turbos.
I personally ran one for several years, added a Edelbrock intake, a 390 cfm Holley 4 bbl, HEI ignition, dual exhaust and it ran very well as well as reliably. These engines do suffer from an inferior oiling system and do not like sustained high rpms, but there are relatively simple fixes for this problem, again lots of information on the net.
Just for informaiton if it is a 65 GM engine, it is a 253 cubic inch also known as the 3800CC used in later GM cars
Good luck
dusty scjconv
PostPosted: Mon Jul 27, 2009 9:03 am
Since when did Buick run a 4 Cyl 2.5 in a Grand National????
PostPosted: Mon Aug 10, 2009 8:27 am
LOL... im with ya on that one..... never.
But anyways, the 2.5 is a great motor for a luv I would think,
has a SBC bell housing, and the exhaust matches the side. they can make alot of power and alot interchanges with v8s if you know what your doing.
there weak link is the crankshaft.
A.j.
