It is currently Fri Feb 15, 2019 1:49 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: 9 inch questions
PostPosted: Sun Apr 25, 2010 9:24 pm
how much did it cost u to cut down ur 9in and stuff
75-luv mikado-V8 350 soon
PostPosted: Sun Apr 25, 2010 10:46 pm
To find out how much cutting axle and replining sxles go to Currieent.com. I had mine done a couple of years ago and I don't remember how much it cost.
You also have to fiqure in the extras, like hot tanking the housing, cutting off old axle pads, welding on the new ones, replacing the wheel bearings, etc, better figure about 5 hundred or so.
Good luck,
PostPosted: Sun Apr 25, 2010 10:59 pm
yeah cuz im starting to think i dont want to tub my luv right now
PostPosted: Sun Apr 25, 2010 11:18 pm
http://www.currieenterprises.com/cestor ... px?id=1563
Part #: CE-2001
Our Price: $329.95
Description: The heavy duty housing features a 26" housing center stamping, 3" x .188" wall swedged tubes, and small, early large, or late style large bearing housing ends. Custom built and mig welded to customer width and pinion offset specs., and comes with 3rd. member studs installed, and the 3rd. member gasket, nut, and washer kit. Our most popular housing!!!
Unit of Measure: Each
PostPosted: Sun Apr 25, 2010 11:25 pm
This looks like a good deal at $329, and one nice thing is the ability to get the later "large bearings" end, that way you can use Explorer rear discs, complete with internal e-brakes. I think it is the cheapest and by far the strongest way to go. I searched e-bay for several weeks and finally bought a Ford 9" "Trac Lock" third member for less that a hundred bucks!
Good luck,
dp
PostPosted: Sun Nov 05, 2017 7:06 pm
hotrod80 wrote:
Come to think of it i might go 53" and run a 4.5 bs . for rim avalibility .
Is this wheel face to wheel face?
