It is currently Wed Jul 01, 2026 3:48 am
PostPosted: Mon May 25, 2009 11:07 pm
i am attempting to swap a chev 4.3 v6 in a 78 luv. motor is from a 85 truck or something. i am still looking for a 5 spd. was wondering if anyone has done this before, and if a 5 spd will work and how to set up the clutch. also, would love itcture, and any infor on mounting the motor and tranny. thanks
PostPosted: Tue May 26, 2009 5:15 am
if you had scrolled down the page just a little you would have found this thread
viewtopic.php?f=6&t=16544
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Tue May 26, 2009 8:47 am
clutch and trans is the easy part.
need a V8 T5, a camaro is a good choice. then you will need an S10 T5. you need to remove the tailshaft housing and swap it onto the camaro unit. this will put the shifter location in the correct area. try to get a regular (F-bodys have 15* tilt for shifter) bellhousing, flywheel and clutch pack can be pieced from autozone. the clutch with convert to hydraulic and the kit is available from summit.
A.j.
PostPosted: Tue May 26, 2009 10:51 am
why not just get a s10 t5 instead? And pick up a bell housing? And what do i do for motor mounts?
PostPosted: Tue May 26, 2009 11:46 am
S10 t5 is weak, the v8 camaro is a little better. Comparison to me is like the difference between a Saginaw 4 speed and a Muncie, but the v8 t5 ain't no Muncie. Course, if you have a deal on a s10 t5, run it, you can always upgrade after it grenades. Motor mounts are pretty easy to fab, if you want to buy bolt ins, there are a couple of threads floating around here with the same info...
PostPosted: Tue May 26, 2009 11:58 am
yea the 4 banger trans will last all of about 100 miles.......... try it........ you will see.
you have to have a chevy v8/v6 pattern bellhousing, but it needs to have the T5 mount pattern. A 4cyl or 60* V6 bell will NOT work.
As for motor mounts, talk to Ol'Rob..... he can set you up.
ever considered a buick V6?
A.j.
PostPosted: Tue May 26, 2009 1:46 pm
i considered a buick ya, but i already bought a chev 4.3, and its mildly built so i figured it would be nice
