It is currently Sat Jul 04, 2026 3:29 pm
 Post subject: 79 4x4 engine swap
PostPosted: Sat Jun 07, 2003 8:13 pm
I have a 1979 4x4 with a tired engine in it.. what could I replace it with that would be easy to install. Im not looking to make it a power house, Just more power than it has so I can to some towing... I am also thinking of doing the trans with the Engine... The one in it is a stick 4 speed.. What engine/tarns combo will be the easyest to install?
PostPosted: Sat Jun 07, 2003 10:51 pm
Resident Sparktrician
I'm going with a hyped up 1.9L Isuzu engine, but it has proven to be a formidable challenge to get all the parts together. If I had it to do again, I would go with a Toyota 22 series, Isuzu 2.3L, or Isuzu 2.6L (Older Troopers have them). If you do this, I would recommend that you grab the 5speed tranny attached to it as well.
This is just my 2 pennies...
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Tue Jun 10, 2003 6:50 pm
Im not looking to hype anything up.. I just looking for something that I can easly drop in and go...
PostPosted: Tue Jun 10, 2003 7:03 pm
how about a toyota 22R engine with 4wd tranny like off a 83 toyota truck or maybe even an 86
PostPosted: Tue Jun 10, 2003 7:16 pm
The motors that I listed wouldn't really "hype it up", but you would get some good power. I would consider selling the 1.9L Isuzu motor that I have for what I have in it. I would probably want to keep the head though. PM me if you want the details.
By the way, I'm in Oregon, so I'm not too far away...
Kuranosuke
Grampa's Driving:
got BOOBIES? 8O 8)
PostPosted: Fri Jun 13, 2003 6:37 pm
77 4x4???????????????
PostPosted: Fri Jun 13, 2003 7:30 pm
Opps typo, thanks.. I missed it
PostPosted: Fri Jun 27, 2003 9:55 pm
i'd either go with a 22r(i own a toyota, know quite a bit about them) or i see that many isuzu trucks had a 2.3l carbed engine, that'd probably work
the 22r and toyota transmissions that went into 4x4 trucks would probably be a good bet. the transfer case output is on the passenger side, not sure about the luv(as i don't own one...yet :p), but i think it's the same as the luv. if you take this route, try to get a W(like a W56) series transmission instead of the older G series such as a weak G52 or G53 that often blew up after 200k because the bearings were too small.
22r engines are well known for their reliability, they usually go 300-400k miles until a rebuild. also, parts are everywhere and they tend to be cheap because the engine was made from 1981 until 1995 at least. it's available in a carbed version, a EFI version(22re), and a rare turbo version(22r-te). stock, the engine isn't blazingly powerful, with about 95 hp, but you can get a few dozen ponies by adding a weber 32/36 or 38, as this motor was notoriously undercarbed. a header can spice things up a bit too, although often to the cost of some torque. but i'm sure that if a properly equipped 22r in a toyota 4x4 can turn 35" tires without any problems, it'd work great in a luv :)
i tow my 13' boat around with my toyota 2wd, bone stock, the only place where it gets scary is on the freeway, since the stock carb bogs it down a bit
PostPosted: Sat Jun 28, 2003 10:19 pm
if your looking to do towing 5th gear or over drive will be useless to you. i would shoot for a 1.9L isuzu whith the same tranny.
PostPosted: Sat Jun 28, 2003 10:25 pm
Sounds good.. but will it just drop in? If not, what mods are needed?
PostPosted: Sat Jun 28, 2003 10:55 pm
i'm guessing the toyota engine/transmission/transfer case might need new drive shafts, and possibly different engine mounts. otherwise it should fit right in the engine bay, you might have to cut a new hole for the shifters though
PostPosted: Sun Jun 29, 2003 1:07 am
I just picked up an Isuzu trooper with a 2.3L and a 5spd. From a superficial look around at it, it looks like the 2.3L and trans/tcase would be a bolt in swap to a LUV, but its hard to tell for sure without a tape measure and a lot of time looking at it.
A 22R would almost definitely take different motor/trans mounts and drive shafts, but I can't think of much else that would get in the way. It is such a common powerplant that finding parts for it would be really easy, both replacement and performance. Sounds like a pretty good deal to me, except that I'm not overly found of toyotas. That is just a personal bias though. ;)
Users browsing this forum: Google [Bot] and 46 guests
