It is currently Wed Jul 01, 2026 7:18 am
 Post subject: drive shaft
PostPosted: Sat Apr 11, 2009 8:30 pm
do i just gota get one made or can i find one that works
75-luv mikado-V8 350 soon
 Post subject: Re: drive shaft
PostPosted: Sun Apr 12, 2009 10:37 am
for what?
If you're doing a v8 swap, there is a good article on this page that deals with all of this stuff.
http://www.luvtruck.com/Information.htm
PostPosted: Mon Apr 13, 2009 1:25 am
Any drive line shop can fix you up on the driveshaft. To keep the cost down, and get on the road, run the stock LUV rear end. You can get higher ratios for it. If you're not doing bonzai starts or hammering the throttle in corners it will hold up for a while. I've seen them go over 100k with a V8.
