It is currently Wed Jul 01, 2026 5:00 am
 Post subject: v8 motor mount kit
PostPosted: Fri Apr 10, 2009 6:56 am
they just bolt up to the old g180 mounts right on a 75 luv???
75-luv mikado-V8 350 soon
 Post subject: Re: v8 motor mount kit
PostPosted: Fri Apr 10, 2009 5:51 pm
The LUV adapters bolt to the stock location on the frame and the stock SB cushions will set down on them just like factory. Again minimally recommend the DOAN 2267 DOT safety cushion on the left.
PostPosted: Fri Apr 10, 2009 7:50 pm
the left side of the motor?
PostPosted: Fri Apr 10, 2009 10:38 pm
The left engine cushion is usually the one that fails from torque. The DOT cushion has a tee and fork that keep it from completely separating, causing problems.
PostPosted: Mon Apr 13, 2009 1:26 am
The original V8 LUV adapters are again available. These are the bolt in, no cutting of frame needed. Retains the E brake. You can use the early double pulleys for Alt, Smog Pump, etc. A complete clean conversion can be done in less than a week.
The instructions for installation can be viewed at http://www.photobucket.com/V8LUV "1 V8 LUV install" and "2 V8 LUV install"
You can also get instructions or a listing of needed parts by emailing tech@powerbyace.com Pricing at sales@powerbyace.com
I understand that the engine, transmission, adapter kits will start shipping on Tues the 14th. V6 4.3 adapters should be shipping in 3 weeks.
PostPosted: Sat Apr 18, 2009 2:41 pm
I want those headers so bad old rob !
