It is currently Wed Jul 01, 2026 11:52 am
 Post subject: which v8 do I have?
PostPosted: Sat Mar 28, 2009 11:40 pm
I need some help figuring out what engine I have, heres the info I could find on it
cast# 3970010
ID#?? VO629OGC (not sure if those are O's or zero's)
vin?? 11k236708
date is really hard to read F25T (not sure about the T)
there is some code on the exterior on the front of the driver side head OASX886
I did several searches on-line all I could find is that it is either a 302/327/350 depending on which web site I looked at
also has a stamp "25GM" on back of block
any help would be great
 Post subject: Re: which v8 do I have?
PostPosted: Sun Mar 29, 2009 12:55 am
Try Mortec.com. That T should be a number...
PostPosted: Sun Mar 29, 2009 4:03 pm
Is it for sale? mortec shows it to be a 1969 302 z28 why can't i ever get that lucky?? I am trying to build a homegrown 301.6
PostPosted: Mon Mar 30, 2009 8:14 am
0010 Block....... 4 bolt main 350.
good base for solid performance.
BUT>>>>>>>>>>>
I have a 302 short block sitting in my garage.
fresh rebuild, wiesco pistons, legend rods, good stuff.... 1500$
A.j.
PostPosted: Wed Apr 01, 2009 12:26 am
soooo..... which is it? i cant seem to get an exact answer, i thought the vin or id# would tell me more, so i will try to get out and take a closer look at the date :?
PostPosted: Wed Apr 01, 2009 2:01 pm
took another look at the date and appears to be F251
PostPosted: Wed Apr 01, 2009 6:32 pm
That isn't a 302 then. IT would be a71 block. IF the bore is 4 inch , it's a 350 block.
PostPosted: Thu Apr 02, 2009 12:27 pm
yea its an 0010 block.............. should be a 4 bolt main 350...........
like we said.
A.j.
PostPosted: Mon Apr 06, 2009 12:19 pm
Ok did some more research and found out it is a 71 350 out of a impala/camaro/chevelle, the 245hp package
sounds like a good one to do a mild build on!
