It is currently Wed Jul 01, 2026 12:55 pm
 Post subject: side draft carburetor
PostPosted: Thu Apr 02, 2009 9:41 pm
does anyone know if they make one for the luv engines and the manifolds. I know they do for toyota's. I was thinking about doing the side draft carb. My boss says he's seen the luv with them on. so where can I buy one or talk to about a kit. thanks
1975 luv daily driver.
Project-soon to be revived
PostPosted: Thu Apr 02, 2009 11:38 pm
Talk to the Catman, he is the expert on those.
PostPosted: Fri Apr 03, 2009 12:26 am
i may have mine for sale not sure yet... but yes they make them,, you will have to peace it together...
get an intake for a Holden Gemini on eBay from Australia . you can get a single or duel, i have had both... and have it shipped over here ... the last one i bought was $36 for shipping but that was over 2 years ago... then get a carb or cars here if you can find a good deal or if not i have a guy in Italy the has good prices on weber or dellortos… if you look at my sum pics you will se both carb setups… just click on my pic below
PostPosted: Fri Apr 03, 2009 1:15 am
thanks for the reply. well I looked on ebay didnt find one. and would the wabber sidedrafts work on that intake. how much did the intake cost you. and how did you like it. the pros and cons of it compare to the regular webb carb upgrade. would it be crazy to try to make my own intake.... :econfused .
PostPosted: Fri Apr 03, 2009 6:38 am
http://cgi.ebay.com.au/GEMINI-RODEO-TWI ... 240%3A1318
http://cgi.ebay.com.au/GEMINI-JACKAROO- ... 240%3A1318
http://cgi.ebay.com.au/HOLDEN-GEMINI-RO ... 240%3A1318
pros are sounds way cool and a little more power... if you dont have a built motor dont run them they wont do any better then a 32/36 if you can get them to run, must be built up... cons are more gas used and a bitch to get tuned just right...
PostPosted: Fri Apr 03, 2009 10:25 pm
thanks for the help. and might i add :esurprised man that alot for the intakes. well just got to start saving money. i do have another motor that Im going to redo. what other thing will I need. is there a different throttle cable, anything else?
PostPosted: Fri Apr 03, 2009 10:27 pm
you can use the luv one , its long enough. or get an aftermarket lokar one
PostPosted: Sat Apr 04, 2009 1:36 am
thank you for all your help. l8t
