It is currently Wed Jul 01, 2026 7:33 am
 Post subject: rear ends and raditors
PostPosted: Fri Apr 10, 2009 8:43 pm
ok im puting a sbc in my luv and every one talks about the motors and not the raditors and the rear ends which rear end should just bolt up if any is alvalabe to get a junk yard and which radiotors u guys run with ur v8s
75-luv mikado-V8 350 soon
PostPosted: Fri Apr 10, 2009 10:35 pm
Use a 22" wide x 19" tall 2x1" row aluminum with Chevy inlet / outlet oriantation.
There are some S10 rear ends that might work. One thing about leaf springs is that you can carefully trim off the stock spring perches and weld them onto a different housing.
We used to make rear ends, where we would put the LUV axle ends onto the 10 and 12 bolt Chevy housing. With axles made from a Chevy 6 lug truck axle core. Use roller bearings with a spacer to make it all fit with stock LUV brakes. Kept the balance in the braking system.
PostPosted: Fri Apr 10, 2009 10:57 pm
some guys are still running the stock rear ends....
PostPosted: Fri Apr 10, 2009 11:11 pm
The stock rear ends hold up surprisingly well. Just DO NOT hammer the throttle with big tires while turning.
Users browsing this forum: Google [Bot] and 53 guests
